Stall install, How'd u plumb? + Tune tables
If you already have the stock cooler, I would stick with that since the stall is basically stock. But I think you should do like Billy and get it restalled to atleast a 3200. With it being a 10.5" converter, I promise you it's going to drive like stock all the way up to a 3600 stall speed. I can keep mine well under 2000 rpms all day long if I wanted to.
PT's Slowest Truck
Ordered my TruCool install kit from Time2Kill on SilvySS.com (also a member here). It has pre-cut aluminum brackets and a compression fitting to adapt the factory auxiliary cooler lines to the trucool. I also went to the dealer and ordered the factory cooler kit, which contains the factory cooler and lines. The factory cooler will be going up for sale as new
![Winky](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_wink.gif)
ARC
57
02-21-2022 10:54 AM
LCHEE
10-24-2020 04:10 PM
Castro45
24
07-31-2015 07:13 PM
lxcoupe
07-14-2015 10:14 PM
