Stall install, How'd u plumb? + Tune tables
If you already have the stock cooler, I would stick with that since the stall is basically stock. But I think you should do like Billy and get it restalled to atleast a 3200. With it being a 10.5" converter, I promise you it's going to drive like stock all the way up to a 3600 stall speed. I can keep mine well under 2000 rpms all day long if I wanted to.
PT's Slowest Truck
Ordered my TruCool install kit from Time2Kill on SilvySS.com (also a member here). It has pre-cut aluminum brackets and a compression fitting to adapt the factory auxiliary cooler lines to the trucool. I also went to the dealer and ordered the factory cooler kit, which contains the factory cooler and lines. The factory cooler will be going up for sale as new
ARC
57
02-21-2022 10:54 AM
LCHEE
10-24-2020 04:10 PM
Castro45
24
07-31-2015 07:13 PM
lxcoupe
07-14-2015 10:14 PM
