Which stall will flash higher rpm's?
Old 06-09-2009, 08:12 PM
richierich14608's Avatar
Default Which stall will flash higher rpm's?
Which one of the two converters I have listed below will be loosest of the two, and also give me the highest stall speed on 5.3L with a 4L60E? The Yank or the Circle D?
YANK TRUCK THRUSTER 3000 4L60E/4L65E
278 mm, 3000 stall, 2.21 STR, 98.6% efficiency!
http://www.converter.cc/converters/truck/index.html
OR
Circle D 278MM Street Series
High Carbon Lock-Up Clutch
Stalls from 2800-3200
http://www.circledspecialties.com/Co...s/LS1-278.html
Old 06-09-2009, 09:28 PM
Where's the Beef?
viciousknid's Avatar
My guess is the Yank will be looser but I can't say for sure. I have the Circle D and mine is nice n tight so I get good MPG's in the city and stalls up to about 2800 with my mods.
I haven't driven the yank tho So i'm not sure if there even is much of a difference in the 2 as far as latency goes.
Old 06-09-2009, 09:39 PM
cwalker2006's Avatar
will it stall to 3000 with slicks? or is it 2800 on your street tires?
Old 06-09-2009, 09:44 PM
Where's the Beef?
thats with my street tires. Don't have any slicks
Old 06-09-2009, 10:11 PM
GMCtrk's Avatar
Both of those converters are reworked TB converters. One costs $550 (Yank) and the circle D is $375. I would go with the circle D even if both cost the same. But it being that much cheaper makes it a no brainer.
Old 06-10-2009, 12:50 PM
Anyone else got experience with these two converters?
Old 06-10-2009, 01:04 PM
Former Vendor
Circle-D's Avatar
I would be happy to answer any questions you have about the converter. Feel free to call anytime.
713-895-8834
Chris
Old 06-10-2009, 11:22 PM
Banned
lucky77's Avatar
not to steal the thread . . but I've been hearing alot about the TBstall coverter . . . is this a good upgrate over the stock stall on my NBBS . . whats the stall # on these tB?
Old 06-12-2009, 07:47 AM
KevinF56's Avatar
I had a TT3000 and it was pretty tight, but it flashed right to 3000
Old 06-14-2009, 08:20 PM
Laid Back
Beatdown Z's Avatar
The TT3000 in my truck is real loose. But I'm sure my truck's size and weight is the reason for it.
Quick Reply: Which stall will flash higher rpm's?
