Started the install on the 1500 series leaf springs & velvet ride shackles.....pics
Here are the changes in ride height and driveline angles
Ride Height:
....................................old........... ................new
Driver Rear...................41 8/16....................40 1/16
Pass Rear.....................41 13/16..................40 5/16
...............................caltracs........... ..unloaded..........1/2 ton susp
diff angle.....................93*....................9 2*.................90*
rear d/s angle...............98*....................96*.... .............96*
front d/s angle..............95*....................93*
trans angle...................95*....................93. 5*
pinion angle w/caltracs loaded -5* (diff 3* up)
pinion angle w/caltracs unloaded -4* (diff 2* up)
new pinion angle -6* (diff 0* up/down)
Ride Height:
Thanks bro, looks like I could count on about 1.5" drop with the 1500 springs, good to know......Now I need to figure out how to notch this thing. This truck has the most complex looking frame shape I've ever delt with. Otherwise it would allready be lower.
Good work grippy and great pics to boot.
The proof will be in the pudding (or so they say) (but who are they?) and I hope it works the way you plan it to.
Looks like you might be able to benefit from a 2* shim back there.
Keep up those crunches. This is getting interesting.
I like the truck in your sig personally.
