Suspension drop question...
My question is if I want to drop my truck 3/5...could I just buy a 3/4 drop kit with coils up front and shackle/hanger kit in the rear, then take the blocks out from the rear to achieve the last 1" drop? Would that work or does taking that block out make much of a difference? Thanks.
Ahhh I didn't realize that the blocks only came on 4wd trucks. Correct, my truck is 2wd. My fault...guess I should've just looked underneath my truck. So taking the overload spring out with get an inch...I take it will decrease the payload a little bit. Thanks 95brightteal!
pls. stop saying that only 4wd have rear blocks. maybe in 06. but not newer. mine is 2wd with torsion bars and blocks... not trying to be a smart ****, but i had someone tell me this too and caused alot of headaches. lol...
now with an ECSB you have an argument.
And i always check to be sure...
can u believe that its stock? tell me about it i am about to do a good 3/4 drop on it and see where it sits. for some reason gm decided to lift it some to fit the 20's on there..
I can almost guarantee the dealer cranked the bars J. that's not set at GM spec'd Z height. And yes, if you have t-bars (2wd or 4wd) and are not an SS, you have rear blocks. Coiled trucks have none.
