Suspension Help Please
Loosened bolts 3 turns each but was still not level. Not sure if it hurt anything but I went ahead and made 1 more turn on each one and now its perfectly level. It seemed fine when I drove it. Making that many turns does it hurt anything?
If it rides fine it's OK. when I lowered the front of my work truck I backed the adjester bolts out so it's barely sticking through the crossmember. That has 25000 ago with no problems.
explain to me the bolts. I see they thread into the cross member but I also see after the pass thru the cross member they run up into a hole or opening in I guess the torsion key, is this right? Mine still look to be thru the cross member and up into the key
That should be ok for now. You can take them out and get the shorter urethane stops.
http://store.summitracing.com/partde...5&autoview=sku
These if you really need the travel.
