Which swap is easier 80e or th400
Old 12-01-2009, 04:13 PM
LsxCody's Avatar
Default Which swap is easier 80e or th400
Well my turbo setup is almost done so I'm now looking into swapping transmissions. I've searched for info but would like to hear ppls opinions. Also I would like to know exactly which parts I need for both swaps
Old 12-01-2009, 04:18 PM
nonnieselman's Avatar
2wd??
RC??
the 80E swap is easy if your 2wd. theres not much different in swapping to a TH400.
If you get a converter built to what you need it would make it alot easier using the stock flexplate.
if you go th400 your goin to need a longer DS. never done a 400 swap just 80E swaps.
Old 12-01-2009, 05:36 PM
Mean03's Avatar
I have done both swaps on my truck...first did the th400 and then the 80e and i by far recommend doing the 80e over the th400...surprisingly enough the cost of the 80e swap was about the same...i had a th400 with a t-brake and all and that cost 1200 with a 700 verter then had to have a DS made that was 400 and had to fab up a mount for it. the 80e i just bought a verter from Yank, pinned the pcm, had hptuners segment me a 80e trans file into my current tune used the same yoke for the th400 and had to shorten the DS about 4'' and made a diff mount for the trans...oh and if you go 80e buy a flexplate for a 98 f-body, it's dished so you dont have to use a spacer....but not having OD sucks *****
Old 12-01-2009, 05:40 PM
Dezert1500's Avatar
400 is much easier and cheaper. My friend and I just did one on his truck and it works amazing. This is a offroad prerunner truck though. If it was street driven I'd spend the extra $$$ and time installing the 4l80e for the OD. If you don't care about OD I'd go 400 all the way.
Old 12-01-2009, 05:43 PM
LsxCody's Avatar
Mine is a ecsb. I will be going with a 2wd tranny. I don't ever use 4wd anyway
Old 12-01-2009, 05:48 PM
LsxCody's Avatar
What all do I need to do a 2wd 80e swap. I know about getting a flexplate and crossmember. What's everything I need minus the converter and trans
Old 12-01-2009, 05:51 PM
High on diesel fumes
thunder550's Avatar
Flexplate, crank spacer, longer flexplate bolts, crossmember, trans, converter, 6 converter bolts, lower bellhousing cover, shifter cable bracket (if the trans doesn't come with one), harness for 2nd speed sensor, driveshaft, extension for the rear cooler line, and someone to swap the transmission segment in your tune.
Old 12-01-2009, 06:23 PM
LsxCody's Avatar
Thanks
Old 12-01-2009, 06:25 PM
LsxCody's Avatar
I can get a 80e converter with 3 bolt holes right
Old 12-01-2009, 06:38 PM
charcold-bowtie's Avatar
yes thats the one I run, with my old 4.8 flex plate
Quick Reply: Which swap is easier 80e or th400
