Swaping to a SF 14 Bolt
Old 04-13-2007, 08:11 PM
  #21
10 Second Truck Club
67SS509's Avatar
Originally Posted by BirchSSclone
I ended up paying just over $2,000.00 out the door. It comes as the whole assembly including the breaks. The rear end comes factory in 05+ 2WD SS silverados and VHO trucks. I believe the 1500HD's use a different housing and they are 8 lug (I believe TurboBerserker used a housing from an HD when he built his custom rear end). I placed my order today and I will get it on Wednesday. I'll make sure to take some pics.
Here is how I did my e-brake cables pic Something is wrong with that price, sounds like you are being charged list price for a bare housing. A 14 bolt drum to drum costs a lot more then that.
Old 04-13-2007, 09:08 PM
  #22
5 year bitches!
Quik's Avatar
i now have the correct Ujoint i got from napa. i can get part number tomorrow
but i did find out something major. the pinion angle with the 14bolt and my 3/4 drop ******* blows!!! its so postive that my ds smacked the floor of the truck when i took the truck for a trial run today. also found out that somehow the SSR that was working for lenght is now shorter. the truck must of settled and now DS is too short
but tomorrow i will hopefully be installing 3* shims i picked up. to see how much that changes the angle
you will probably need shims even at stock ride height to get it correct. i think i might need more then 3* worth of shims
Old 04-13-2007, 09:24 PM
  #23
BirchSSclone's Avatar
Thanks for the pic. And as far as the price is concerned, I've got connections
Old 04-13-2007, 09:25 PM
  #24
Yea if you can post the part number I would greatly appreciate it. I'm at a 4" drop in the rear too, so more than likely I'll need the same shim.
Old 04-14-2007, 05:52 PM
  #25
67SS509's Avatar
The NAPA part no. is 240-0447 for the u-joint that goes from the 1350 yoke down to the stock size. Only problem is no one offers it in a heavy duty version. I searched high and low but came up empty. I just decided to go with a Denny's driveshaft and 1350 joints front and rear.
Old 04-14-2007, 10:09 PM
  #26
5 year bitches!
Quik's Avatar
yep your right on that one. i just grabbed my box and was going to post the number and you already did this
Old 04-14-2007, 10:11 PM
  #27
5 year bitches!
Quik's Avatar
ok heres my results...... i used a 3* shim and now my pinion angle is straight with the driveshaft. so its nice. i wish i could make it alittle negative i might get another shim to drop it down some for hooking but right nwo its how it should be
so 3* shim iswhaty ou need with 4" rear drop and 14bolt
i also found out somehow even with my t56 and 14bolt my stock DS is correct lenght. i guess my rear settled with truck being driven
natejk
11-15-2016 08:05 AM
Justin87gn
09-10-2015 12:06 PM
2004gibbstruck
09-07-2015 06:05 PM
iregret
09-07-2015 01:20 PM
Cowboy Tom
09-05-2015 04:29 PM
Quick Reply: Swaping to a SF 14 Bolt
