sway bar is hitting the tierod?
Id lift it higher if I could without throwing a body lift or a different suspension on it, Im just trying to figure out what is causing this since it just started...im sure its something obvious
took it to firestone to get it aligned and see what was wrong, idler arm and bracket was pretty worn out and when I turned it to the right, it would bind up the tie rod against the sway bar, its fixed now but its still pretty close to the sway bar...Thanks for the help
well Im going to tighten up the sway bar links and see what that does, they pivot and lean a little. The sway bar and tie rod both have grooves in them from where it was grinding so this is more serious than I thought
as for the cv boots, they are good, it looks funny in the picture but they should be good for another year or so hopefully
Right now the truck is in the shop and taken apart, shes getting the FLT installed so Im looking into this more since I have a shop I can borrow for the moment and trying to figure this crap out.....
carid
10-01-2015 09:22 AM
