Sway bar tech
Old 01-23-2011, 09:59 AM
TURBHOE's Avatar
Default Sway bar tech
What's better solid or hollow? I would think solid but I'm not sure. Any body have some good info on this? What sway bars do you run and how do you like them?
Old 01-23-2011, 10:12 AM
08cheyennesc's Avatar
NORCAL TBSS posted something about this last night on his DJMS new massive swaybars thead, I just don't know how to get the link in here.
Old 01-23-2011, 10:43 AM
traveling mod
andrew383's Avatar
Alot of the aftermarket bars are solid vs the hollow stock ones..The hollow one will twist more of course..
DJM and Belltech offer bars for the tahoe although i dont have any feed back for them
Old 01-23-2011, 11:23 AM
MikeGyver's Avatar
Hollow ones are lighter and they can be made to work. In a race car, a hollow one would be used. The difference is that a good hollow one needs to be made of higher quality steel than a solid one, and being more stressed than a solid one of the same anti-roll stiffness, it will probably not last as long.
Old 01-23-2011, 11:48 AM
Praise The Lowered
RibeiroBJJ's Avatar
I worked on alot of different suspensions over the years and have seen quite the opposite..The oem are solid and the aftermarket are a high quality hollow tube..Not only do the oe mfgrs. have the money to create a mold for solid but they use it for 500,000+ cars/trucks...The aftermarket dont have that type of money so they use a tube bender to create a hollow one and use a jig (airride tech, hotchkis, djm, addco)
For us sport truck guys I think hollow is best to shed some wieght....imo of course
Old 01-23-2011, 11:49 AM
2004SSS's Avatar
i have hotckis anti sways on my truck imo they are very nice . the bracket that bolt to them frame are nice quality and pretty easy on install. they are hollow and a large diamter.
i dont have any pics right now but they face the oppostie ways most do , they bolt to the frame in front of the rear axle where as most other bolt to the crossmember in the rear. mine are setup with caltracs and dropped 3" in the rear with no problems. the only thing is if you have a rear girdle you need the low pro one.
Old 01-23-2011, 12:40 PM
TURBHOE's Avatar
I found a company that makes huge ones 1 3/8" that are solid. With a dmax in the front I would think I need some beefy ones. If weights not an issue will huge solid ones work better?
http://www.summitracing.com/parts/HEL-7702/
Old 01-23-2011, 12:58 PM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
The DJM front is 1.5 and the rear is 1.375 I believe
Old 01-23-2011, 01:06 PM
TURBHOE's Avatar
damn thats huge. how thick is it?
Old 01-23-2011, 01:08 PM
1slow01Z71's Avatar
Believe they are solid
Quick Reply: Sway bar tech
