T/A Girdle? Help pls...
Anyone running one of these? Since I have the stock housing, but Auburn LSD what part # shud I be getting - GM 10bolt 8.2-8.5"? My truck has 5 link and Eibach sways, so wonder if it'll fit? Last, the load fasteners for the bearing caps...how do you know how much to tighten them? I'm sharp as a bag of marbles when it comes to this stuff!
I don't know where your sway bar crosses the housing but you may want to get the Low profile model. I did and didn't really need it.
Model # 1807A
http://www.taperformance.com/products.asp?cat=48
Model # 1807A
Crosses right behind the cover...I'll measure the clearance from the OEM cover and ask T/A what they suggest. Thnx again for ur help!
Model # 1807A
Model # 1807A
11 Second Hall Moniter
http://www.installuniversity.com/ins...id_install.htm
Also gonna recommend you buy a low-profile cover for your app.
5 ft/lbs. Then tighten jam-nut. Here's a link for install instructions.
Model # 1807A
Model # 1807A
If possible, in a way, we can see the clearance u have in your app?
