TA Girdle installed w/ pic
#21
PT's Slowest Truck
Originally Posted by joehawkz71
where is everyone buying these covers i was plannning on replacing mine since i wanted to change the fluid and its leaking!! im pretty sure i can figure out where snakeoiler got his!
also quik did you go with the full floaitng 14 bolt rear end(8lug) or did you just get the 14 bolt with 6 lugs?
#22
I got mine straight from TA Performance, I called and ordered it over the phone. You can find their website if you Google em
thanks....they didnt have prices from what i look at what did you pay??
#23
Mine has recently started leaking out of the stud bolts, drain plug, and somehow the fill plug. I'm going to put teflon tape around all of them in the morning. I reccomend everyone pull every bolt out and do the same when they install theirs.
#24
11 Second Truck Club
Originally Posted by SnakeOiler
Yeah, I used the Summit cover with ARP bolts:
http://i2.photobucket.com/albums/y28...o/RearDiff.jpg
They look like they have no heads on them...even when I enlarge the pic...
also...I assume that the stock bolts are too short to re-use...is that correct?
what size and thread is required?
