Take a look at my gear pattern.
#21
Well I called the installer and he was pretty rude today saying how they are just a loud gears and I'm fretting over nothing and he may be able to look at it Wednesday.. Sooo, I bolted the radials up, filled a bottle and am going to make some hits to see if it gets worse.
#23
Laid Back
He did manage to tell me depth is .035 and he set back lash "tight" at .006
But these were his words. I don't know if he's telling the truth or not.
I'm almost wondering if it's in the tru trac since he put synthetic oil in it with these helical gears causing a whine.
My TruTrac works better with conventional fluid. It did some weird **** with synthetic(no whining though).
#24
.035 is one of the most common pinion shims for ten bolts and .006 is the bottom of the backlash spec if you were to look it up. So it's possible he could of told you those numbers just to shut you up. For all you know, he may have set it up with his magic hands like George.
There's tolerance on everything. A good mechanic is only as good as the instruments he's using to measure the .035-.037 and the .006-.010 ranges. I don't like the explanation of "tight" .006 he gave you. How much .in/lb. torque did it take to rotate the assy. after he installed it? That would bear out any set up problems including the pinion bearing pre-load being excessive.
I've got 4.56:1's front and rear along with a Tru-trac and it's dead silent.
Defective ring and pinion sets are very rare these days. The pattern on the gear teeth are proof that they were setup incorrectly.
