TCI shift kit now "No Reverse"
Old 06-28-2008, 10:59 PM
FLT
FormerVendor
FLT's Avatar
Two other things to check would be to make sure that you have the "Three (3)…....2-1/8"…...8mm………E" bolts installed in the correct locations. Also make sure that the boost valve sleeve is fully installed with the snap ring in it's groove. This will create a huge leak. Also double check the advise in my first post in this thread.
Old 06-28-2008, 11:00 PM
FLT
FormerVendor
FLT's Avatar
Originally Posted by da_vato
I do remember putting the "V" the wrong way now that you say that. But that wouldnt cause a no reverse you say. And another thing does the pin go through the hole?
Yes it does go through the hole.
Old 06-28-2008, 11:04 PM
da_vato's Avatar
Thanks for the help. Ill let you know how it goes.
Old 06-28-2008, 11:06 PM
FLT
FormerVendor
FLT's Avatar
You got it.
Old 06-28-2008, 11:21 PM
FormerVendor
Derek @ EDO's Avatar
Vince FTW!
Old 06-28-2008, 11:24 PM
FLT
FormerVendor
FLT's Avatar
Originally Posted by Derek @ EDO
Vince FTW!
Now if I could just get some Becks for everyone of these threads!
Old 06-28-2008, 11:45 PM
FormerVendor
Old 06-28-2008, 11:54 PM
da_vato's Avatar
mmmmmmmmmm one of my favs too.
Old 06-29-2008, 12:01 AM
FLT
FormerVendor
FLT's Avatar
Thanks but now I need to clean my computer screen! I think I should have specified the delivery destination!
Old 06-29-2008, 03:26 PM
James B.'s Avatar
If the pan doesn't have a drain plug you can use refigerator icemaker tubing (clear plastic) as a siphon down the dipstick tube to remove some fluid. You can't get it all this way because there's a little plate in there that the dipstick normaly bottoms out to but you can get enough out to prevent the fluid from cascading over the side of the pan when you loosen it. You can easily re-use the ATF this way since you probably just spent a small fortune on it.
I've seen the condition you speak of when the manual valve linkage wasn't reconnected before bolting in the valve body. Vince already mentioned this. Unfortuately you'd have have to unbolt the valvebody to reconnect that if that's what the issue is.
Quick Reply: TCI shift kit now "No Reverse"
