TECH: Gearing GCSD3742's Truck
Yup the trutrac is a nice piece, thats a 14 bolt unit MUCH bigger than the 10 bolt we all have, this is the 10 bolt
and congrats looks like the truck is coming along nicely
Thanks for the comps gentlemen. I know that I will have a competitive ride, but I know I will never reach the stamina that most trucks have now like a turbo or the juice. I'd like to learn what the truck can do without making an experiment out of it. I try and keep it conservative since I have a house note like many to take care of.
Here is a shot of the new guts going it.
Now to get technical:
The ring gear bolts are a left hand thread and require a 3/4 inch socket. The torque spec for them is 65 ft.lbs. There are 10 of them, and they need to be tightened in a criss-cross pattern.
The ring gear bolts are a left hand thread and require a 3/4 inch socket. The torque spec for them is 65 ft.lbs. There are 10 of them, and they need to be tightened in a criss-cross pattern. Oh, and the use of threadlocker is VERY important.
Question from the novice...what is that gold stuff in the gears? Or is that just glare?
Alright, before stabbing everything in, I had to check and double check the pinion shim thickness. Since I have done 4.10s MANY times, I know that .035" to .037" shim works.
Once the pinion is in, I install the differential and check the backlash. The specs for these gears is 6-10 thousanths. This one hit right at 7 thousanths.
Close up:
Close up:
