TECH: Installing Gears in a 2014 Silverado
Custm2500's Rude Friend
Curious about the Axle shafts.
1.What is the spline count?
2.Do you know what the axle bearing journal is? I am curious if it's a standard 10 bolt axle bearing like on the hybrid AXN 9.5 14 bolt rear end.
Any info now or in the future would be great. Thanks!
Did some checking. According to fme-cat.com (awesome site btw), the 2014 9.5" uses bearing 513067 which is the same as found in the AXN 14 bolts, and 10 bolts. Bearing bore is 1.612"
The big bearing 14 bolt uses bearing R-1561-TV. Bearing bore is 1.7055".
Yup. Bastard. I used a 14SF master install kit however so the carrier bearings and pinion bearings are similar.
Like said though, it appears the FACTORY inner pinion bearing is different than what is in the install kit. To be safe, the set up bearings should match what is in the install kit as the bearing/race stack-up of the factory bearing may be different.
