Th350???
You've got three options, I've only used one.
1.) Use the front wheel sensor as your vss reference, I've used this and it worked fine, only no more abs
2.) Dakota digital makes a pulse generator that mech connects to the th350 speedo gear and then wires to the vehicle vss input.
3.) Spend the $$$ on a new tailshaft housing
Well at the stage that my trucks in anyways I could give 2 ***** less on having abs haha. Do I have to remove any abs modules or anything after this. ?
Next do u have a link to option number 2 for the sensor conversion oFf tha tranny
cut/connect the wires for one of the front wheel speed sensors, then connect them to the two wires for the trans speed sensor. You can't leave the front speed sensor connected to its original pcm connections. Then you'll have to go into the speedometer tables and play with the pulse counts until the speedometer is accurately displayed.
Yes n no i dont know the whole details but they are similar such as in my 400 im using a 4l80 hub unit for internals since its a bit better due to design. but im no tranny expert jus know what my builder n i discussed so far...
[/QUOTE]
cut/connect the wires for one of the front wheel speed sensors, then connect them to the two wires for the trans speed sensor. You can't leave the front speed sensor connected to its original pcm connections. Then you'll have to go into the speedometer tables and play with the pulse counts until the speedometer is accurately displayed. [/QUOTE]
everything is still up in the air for me but using that sensor how would i dissable the abs completely in the computers..
[/QUOTE]
jshouse
09-12-2008 03:20 PM
