are their any 80E don'ts?
only complaint i have is the converter comes unlocked when you completely let off the throttle. it doesent bother me at all since you can just let off and know it will kick down a gear and not be locked when you got wot .
I honestly do not believe this to be true. If anything I would think that it would help. Reason being is over run clutch is applied in all gears applied in the D3 range helping out the OD roller. In the OD range the over run clutch is not used and only the roller is holding. With that being said I would think that the OD roller is weakened if being loaded hard in the OD range. HTH Vince
