Those with Wilwood 16" brake help TC6R
Which brake lines do you run for a 2006 Silverado 1500? I know the part number given on the website is 220-8998 but it comes with a straight fitting off the caliper that I find odd and they are 31" long lines which seem huge.
I have belltech lowering spindles, and my truck is 4wd suspension, so my brake line is in a different spot than coil spring trucks. I purchased 220-9885 which has the 90° fitting and 24" lines. I wanted input from those that have installed the kit as to which lines you picked
I plan to call Wilwood tech this morning when they open, but I'm worried they will just give me a copy paste answer for my question and tell me to get the 220-8998
Great pictures, thanks. What I'm going to do is measure my current SS lines and see what length they are, then mount a caliper to see if it turns lock to lock. I didn't want to get knee deep in the install and realize I can't finish because of brake lines.
The 2wd trucks definitely need that 31" line, no doubt about that
