thug
thug
question guys. my 08 avalanche with a 3/5 drop and a spohn adjustable panhard bar. at a stop, light turns green, i punch the gas and theres a thug from my rear suspension. what could that be? i was thinking my upper and lower control arms bushings in the rear is bad. i jus ordered the spohn uppers and lower arms. anything else i should check?
Mine was doing the same thing for awhile until i figured out what it was. The frame mounted bracket hole was elongated (stretched side to side) and it allowed the lower control arm to move and create a metal to metal sound. I removed the lower control arm and stuck the bolt through the hole of the bracket to see where the metal was out of circle. I then welded metal to the bracket hole and filed/drilled down the excess weld to reform it into a circle again. After that i never had a problem and it's been 3 yrs. Hope that helps.
denali_on_26's
11-26-2013 12:35 PM
slowprocess
01-28-2006 09:38 AM
