time for a flush
Old 03-09-2008 | 01:53 AM
andrew383's Avatar
traveling mod
Default time for a flush
tranny flush that is,anywho i was thinkin bout having royal purple put back in when it gets flushed.would this be a bad idea?or should i stick with the reg G.M. stuff???
Old 03-09-2008 | 01:57 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
I was/am confused about synthetics for tranny fluids. I run what FLT tells me to use, Dex III.
Old 03-09-2008 | 03:30 AM
MeanZ71's Avatar
I run RP transmission fluid, the guy that helped on the tranny rebuild suggested it. He said it will stay cooler under hard driving conditions compared to regular ATF (I don't have a tranny temp guage, so don't know for sure). Crap is VERY expensive, like 9-10 bucks a quart and around 16 quarts for flush and refill...
Old 03-09-2008 | 04:56 AM
SBTork's Avatar
if it's on your '07, I'd stick with the regular GM fluid. In 2006 GM went to Dexron 6 ATF, a synthetic transmission fluid from what I know. We can't even get Dex3 from GM anymore. That should be more than sufficent under most apps.
Old 03-09-2008 | 10:54 AM
andrew383's Avatar
traveling mod
huh ill have to see about goin that route,its prob not much cheaper than rp tho
Old 03-09-2008 | 02:03 PM
SBTork's Avatar
not much, I think the dex6 runs a little under $5 a qt, I think rp is prolly $7 or so a qt, just a guess on the rp.
zblee
63
06-10-2023 02:25 PM
6LITEREATER
01-26-2016 05:21 PM
kr1s
08-24-2015 06:34 PM
lycominghunter
08-15-2015 01:26 PM
N/ALS1
11
07-13-2015 11:56 PM
Quick Reply: time for a flush
