times with tb stall HELP!!!!
A friend of mine was running a 26 x 10.5 ET Street on a 15 x 8 weld drag lite wheels. The car wouldn't 60ft good on motor and wouldn't hook at all leaving off of the Trans Brake at 4000rpm. He then put the 26 x 10.5 ET Streets on a set of 15 x 10 weld drag lite wheels. He also moved his battery from under the hood to the back of his car and now can leave off of the Trans Brake and achieved a new best 60ft. It was amazing the difference it made going with the wider wheel and moving the battery.
5 year bitches!
i can cut 2.02 60' times on street tires with the trailblazer stall. bolt ons only. was running 2.18-2.23 60' before the stall. 1.95 is my personal best but it was on slicks. if your breaking traction now and you werent before, it explains the slower times.
thats what i thought i should of done better but couldnt hook up. i should just take the stall out and put the stock one. cuz im affraid if i buy bigger and wider slicks i'll still wont hook up.
Originally Posted by Quik
i got a best of 1.97 on street tires and stock stall last year in the 5.3 setup, you should of done bette with slicks
what do you guys suggest i do for a launching technique? i tried stalling at 1500 up to 2000 and didnt work what do you guys suggest on how high i should stall without putting caltracs.
