Tire size increase/speedo
I am looking at upsizing the tires on the burb, the overall diameter will be 1" bigger. Will I see any difference in the speedo or is this acceptable. Thanks.
If your stock tire diameter is 30.6 " like mine then you will see about a 3.3 % increase in speed. So at 60 mph you will actually be going 62 mph. That doesn't sound too out of line to me. if you know someone with a tuner they may be able to adjust for the tire size for you. You can probably get away with that tire size increase without any problem.
High on diesel fumes
I had 265/75-16s stock, went to 285/75-16, seemed pretty straight on by the speed signs. When I had my pcmforless tune done I had them program fro 285's, now I'm really going something like 4 mph slower than my speedo reads....last speed sign said 74 when my speedo said 78-79. You should be fine without a tune.
Lamartian92
09-10-2015 09:27 PM
Lamartian92
08-21-2015 01:43 PM
luisalmighty09
08-20-2015 11:35 PM
