Tired of the GM lean!
Old 04-18-2007 | 01:50 PM
CHEVRACER83's Avatar
Gm Has A Bulletin About The Lean... I Will See If I Can Copy It Over
Old 04-18-2007 | 01:55 PM
Subject: Vehicle Lean - Left Front Sits Low or Right Rear High (Add Spacer Between Left Rear Spring Pack and Axle) #06-03-06-005A - (01/12/2007)
Models: 1999-2007 Chevrolet Silverado (Classic) 1500 (½ Ton) Series
1999-2007 GMC Sierra (Classic) 1500 (½ Ton) Series
with Two-Wheel Drive
This bulletin is being revised to update the models to reflect that bulletin only applies to 1500 (½ Ton) Series. Please discard Corporate Bulletin Number 06-03-06-005 (Section 03 -- Suspension).
Condition
Some customers may comment that their vehicle appears to lean. In most cases, the vehicle will sit low left front or high right rear.
Correction
Measure fender wheel-opening heights, front and rear, to quantify vehicle lean. Fender wheel-opening heights are related to, but distinct from, trim height (a.k.a. Z and D height). The front wheel-opening height is known as P height, and the rear wheel-opening height is know as R height. The P and R heights are not set at the factory, nor is a specification given for them. However, they are the most direct and repeatable measurement of what a customer would see as the vehicle leaning. Perform the following before measuring the fender wheel-opening heights:
• Make sure the vehicle is on a level surface, such as an alignment rack.
• Set the tire pressures to the pressure shown on the certification label. Refer to Label - Vehicle Certification in General Information.
• Check the fuel level. Add additional weight if necessary to simulate a full tank.
• To ensure proper weight distribution, make sure the rear storage compartment is empty.
• Close the doors and hood.
P Height and R Height Measurements
P height and R height are measured the same way. They are the distance from the ground to the highest point on their respective wheel-opening, going through the center of their respective wheel. Record the measurement on the repair order.
If the difference from left to right for P and R height is 15 mm (0.59 in) or less, no repairs are suggested as the vehicle is within specification. If the difference exceeds 15 mm (0.59 in) for either measurement, install the spring spacer to the left rear side of the vehicle following the procedure below.
Raise and support the vehicle.
Support the rear axle.
Remove the U-bolt nuts, remove the U-bolts and anchor plate. Discard the U-bolts. DO NOT discard the nuts or anchor plate.
Remove the lower shock nut and bolt.
Raise the vehicle or lower the axle enough to allow for installation of the spacer. Install the spacer, P/N 15872657.
Lower the vehicle or raise the axle.
Install the lower shock nut and bolt.
Tighten
Tighten to 95 N·m (70 lb ft).
Install the anchor plate, new longer U-bolts, P/N 15872655, and nuts.
Tighten
Tighten the nuts to 72 N·m (53 lb ft).
Remove the axle support and lower the vehicle.
Re-check the P and R heights in the previous location. Record these readings on the repair order.
After all measurements are done, perform a road test and check headlight aim.
If these steps do not resolve the condition, please contact GM TAC for further diagnostic assistance.
Parts Information
Part Number
Description
Qty
15872655
Rear Spring Spacer
Rear Spring U-Bolt
Old 04-18-2007 | 02:02 PM
Scream's Avatar
MOOBIES Moderator
I wish that would work for me, but since I have a flip kit in the back I can't raise the left rear, so I should lower the right rear for the same effect, right?
Old 04-18-2007 | 02:13 PM
THAT SHOULD BE CORRECT
Old 04-18-2007 | 09:34 PM
04GIBBS's Avatar
Awesome man thanks for looking out much appreciated.
Old 04-18-2007 | 09:41 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
What about 4x4 bud? Would't the same work?
Old 04-18-2007 | 09:50 PM
1TRUESS's Avatar
Don't all these fixes mess up the vehicles alignment?
Old 04-18-2007 | 10:51 PM
Dirty 30's Avatar
LS1Tech Whore
why exactly do they lean? mine leans alot, looks as if the rear of the chassis twisted. BTW, when i swaped my bed and was driving without one, i noticed that the rear of the chassis flexes A LOT from side to side. Could that be a problem?
Old 04-19-2007 | 03:02 AM
allenmehrer's Avatar
so how thick of a spacer are we talking here?
Old 04-19-2007 | 05:23 AM
Keith's Avatar
Going from the front: The battery(~35lbs), You(171lbs average) and at least 26 gallons(156lbs) of gas are on the passenger side.
Quick Reply: Tired of the GM lean!
