tires for a 4/6 drop??? please help
I have a 99 silverado single cab 4x4. I removed the rear lift blocks and installed 2" drop hangers, and 2" drop shackels... Up front i installed 2" drop spindles and drop keys which helped me drop 2" inches more for a total of 4" up front. Im running texas edition 20" wheels. I orderd 275/40/20s and 295/40/20 out back.. what u guys think?
I have a 99 silverado single cab 4x4. I removed the rear lift blocks and installed 3" drop hangers, and 2" srop shckels... Up front i installed 2" drop spindles and drop keys which helped me drop 2" inches more for a totale of 4" up front. Im running texas edition 20" wheels. I orderd 275/40/20s and 295/40/20 out back.. what u guys think?
Im keeping the 4x4. Its always at 2hi unless at the track then i launch at 4hi.. Alot of guys over at SilveradoSS.com have done the same drop with the same tires set up and have had no problems. Im going to do away with my drop keys and shackels and go with a flip kit and lowering control arms up front....
275/45-20 seems to fit perfectly on a 2wd 2/4, sounds like you have what would be a 4/4 on a 2wd. As for the lowering control arms up front, are they a different size/length than the factory control arm, or just re-indexed, which would essentially be the same as using lowering keys? I was interested in getting LCA's in the distant future, but heard that all they do is re-index the way that the torsion bar goes into them.
To the OP, if you ask enough people, you will get the answer that you want to hear. It's called rationalizing. To make it clear to everybody else, it is NOT cool to mis-match tire diameters on any 4x4 vehicle that was not specifically designed for the mis-match. You WILL accelerate wear on the drivetrain components, if something doesn't break(too large of mis-match).
Lamartian92
09-10-2015 09:27 PM
Lamartian92
08-21-2015 01:43 PM
Codog
08-16-2015 08:23 PM
Porscharu914
08-10-2015 10:57 PM
