Tires or Gears?
Currently have 3.73 gears and 30.5 inch tall tires. I'm not sure if I should go to a 28 Inch tall tire and stay with the 3.73 or keep the 30.5 inch tall tires and go to a 4.10 gear. From what i've heard doing either of the 2 will increase RPM by about approx. 300rpms at cruising speed. I would think going to a shorter tire would be better because it would weigh less and It would be like going to a lower gear. I'm not worried about gas mileage because I only drive about 20 miles per day. Opinions on this?
11 Second Truck Club
3.73's to 4.10's the rmp's will maybe be half of 300rpm increase.
i went from 3.42's to 4.10's and the rmps increased 300 to 350 rmps.
i say it's your choice. with stock height tires (around 30") i'm turning 2300 @ 70.
Not tryin to thread jack but i have the stock 3.42's and was thinking about goin to the 3.73's.I currently turn 1950rpms at 70mph so it would only go up to like what...about 2150rpms are so???
![Cool](https://www.performancetrucks.net/forums/images/icons/icon6.gif)
Originally Posted by Mort
When you go from 3.42 to 3.73 you change your ratio about 10%. That is 3.42*1.10 = 3.76:1. So your rpm will go up by about 10% as well if you keep the same tires. So that would be 1950*1.10 = 2145rpm @ 70MPH and you are correct.
With that little of an increase i just might have to go with 3.73's to help with my off the line..
![Devil](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_devil.gif)
