too much tranny fluid?
I drained my 4l60e pan through the drain plug yesterday while changing my oil, measured exactly 5 quarts that came out, and then I poured exactly 5 fresh quarts back in. I just checked the fluid this morning while cold and there seems to be too much, the fluid goes about an inch past the "hot" cross hatch. Do I just need to slowly drain a little more while continually checking the cold dipstick level? Thanks guys
i let it idle for about 8minutes, and the the fluid is still a good half inch past the "hot" cross hatch, how much fluid do i drain?? my tranny temp guage is still completely cold tho, even tho the engine warmed up to a good 185
you want your trans at operating temps, so maybe let it warm up some more. Take it on a short trip then check it. You check it also while the truck is running, dont kill it.
