Torque converter bolts
I triple recommend the ARPs!! mine have been out about 20 times and they dont even have a scratch on them.. Pretty cheap too.
I always had one 8mm allen head socket just for them freakin stock bolts that were soft.
get a hammer and hit the socket a few good times and when your trying to break them loose be sure to keep the socket straight, get it off center and you just stripped it.
Just like taking out a normal bolt, pretty basic. Use a 3/8" socket wrench with a 15mm 6 point socket and use the block as the leverage to keep the socket wrench straight. If you don't have enough muscle to break the bolt free slip a deep socket on the end of the socket wrench with a 3/8" 6" extension as leverage. They come out no problem.
If you have a billet converter you will need to make sure the bolts aren't to long. I always buy new factory bolts for non-billet converters and they have worked fine on every truck I have done.
I was hoping someone may have some tricks to offer. A certain bit, use a torch etc etc.
And since I'm sure I may have stripped one, or three I was hoping yall may have some ideas
i use a allen socket on a 3/8s ratchet and i slide a 2 foot cheater pipe on it... make sure you hold it straight and it goes POP when it breaks loose!!!! never strippped one out before... i guess you could use a big pair of vice grips to get them off it they are stripped... you could pull the trans off and heat the converter up with a torch... where the bolts are and that should help get them out....
Where you this morning when I was fighting with it lol. I think I stripped one. I can't get my vise grips to hold cause it's at a slight angle.
I hate to pull the trans off the converter. I got it on stands in the ole ladys parking spot. Shed be pissed if I let that much transmission fluid soak into the carport
BennyB
08-01-2015 08:48 AM
KyleW707
07-29-2015 08:17 AM
