Which Torque Converter to get???
While I'm ready to pull the trigger on a torque converter for my build. The engine is a LQ9 6.0L with Comp 223/231 .610/.617, 112lsa, L92/Ls3 Heads w/ 68cc chambers and Patriot Gold .660 lift spring and stainless valves, LS3 intake manifold, Comp Push-rods and Ls2 Timing set. The Truck's got a 3.73 Posi rear end.
Max budget: $500 or a little bit more.
I was looking at these:
YANK TRUCK THRUSTER 3000 4L60E/4L65E
278 mm, 3000 stall, 2.21 STR, 98.6% efficiency! This converter is a modified Truck Thruster 2600. Being so, it shares the stock-like appearance, super-high efficiency, and impressive towing capacity of its lower stall brother. $575 + $55 shipping to AK
Circle-D GM 278mm HP 4L60E LS Torque Converter with 3000-3200 stall speed. $395 + $100 shipping to AK
TCI 242931 - TCI Streetfighter Torque Converter with 3000-3400 stall speed. (I've heard these aren't to good)
About $500 with free shipping to AK
Which one should I get for my setup, keep in mind this motor is in my 1969 Chevy Std Cab Short bed stepside.
can the first one not cause its a YANK ( they make damn good converters ) can the last one cause i dont care for them lol ( hahahaha no reason reason sorry ) so that leaves you the middle which is circle-d hmmm now all i can say is i am very pleased with my reworked converter by them and 99.99% of the people who has them luv them.. BUT why limit yourself to a 3000-3200?
did ya talk to chris and you both came up with that stall speed?
go circle-d 3200-3400 pending on use of truck
I had the yank in mine at first, good stall but vary tight for my 5.3 but would work good for your 6.0, id go with circle d cause everyone thats got one is 100 percent happy with them. tci is garbage id rather keep the stock one then put that thing in there.
I'm thinking I'm going to go with the Circle-D.....3200. I don't really want to go over that stall speed I'm just making this truck a fun cruiser and I might run it at the track once just to see where it stands.
