View Poll Results: WHICH TORQUE CONVERTER
YANK 9.5"
![](https://www.performancetrucks.net/forums/images/polls/bar2-l.gif)
![](https://www.performancetrucks.net/forums/images/polls/bar2.gif)
![](https://www.performancetrucks.net/forums/images/polls/bar2-r.gif)
![](https://www.performancetrucks.net/forums/clear.gif)
35.71%
EDGE RACING 9.5"
![](https://www.performancetrucks.net/forums/images/polls/bar3-l.gif)
![](https://www.performancetrucks.net/forums/images/polls/bar3.gif)
![](https://www.performancetrucks.net/forums/images/polls/bar3-r.gif)
0%
PI VIGILANTE 9.5"
![](https://www.performancetrucks.net/forums/images/polls/bar4-l.gif)
![](https://www.performancetrucks.net/forums/images/polls/bar4.gif)
![](https://www.performancetrucks.net/forums/images/polls/bar4-r.gif)
18
64.29%
Voters: 28. You may not vote on this poll
Torque Converter Poll
Precision is telling me to go w/ a 2800 Stall??? I figured at least a 3000k, I wonder if its too much
I'm told the 2800 will take better advantage of my power curve. Seems most of you guys are running 3000-3600k.
Another Mfgr. recommended a 3200k w/ my setup. I'm just not sure?
I'll just go 3000k (middle of the road) unless I am convinced otherwise, thanks guys.
- 4l60e
- 4700lb truck
- shifting @ 57-5800 rpm
- 3.73 gears
- 31" tall tires (street)
- F/I (supercharged)
- stock cam
![Icon Confused](https://www.performancetrucks.net/forums/images/smilies2/icon_confused.gif)
- 4l60e
- 4700lb truck
- 3.73 gears
- stock cam
Originally Posted by 2004SSS
i have a tcs 3000 right now and im thinking of pulling the trigger on a pi 3200 9.5 multi disc.
is there a 5 disc converter from pi?
P/I Vigilante:
9.5" lock-up 2004R, 700R4, 4L60E, 4L80E
Multi- Disc 5 plate
2400-6000 RPM's
Tin Foil Hat Wearin' Fool
What kind of supercharger do you have, that will make a big difference in what kind of converter you should go with. Im guessing a BD-11 is some sort of centrifugal s/c if so then I would go with a 3200 or 3600, 3600 will be good for when you put a cam in later.
Thanks man. This whole f-ing process is making me
![EEK !!](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_eek2.gif)
Originally Posted by bluecajun5.3
your shift extensions are going to suck with that low of shift points and that 3k converter.
Originally Posted by 99LoweredSierra
lift your shift points and go with a 3200 yank ss
Makes sense. Main reason I'm not shifting any higher is to avoid over clocking the S/C with the 11lb. pulley and stock Crank pulley. I guess it might be better to drop back to a 9 lb. pulley and move my shift points back to 6k (or rev. limit) for better overall performance? Thanks, I hadn't really considered "adjusting" my power curve in that way yet. Correct me if I'm missing the point here. it's 4am
![Sleepy](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_zzz.gif)
