Torque converter swap ?
Alright I have some time off and wanted to get to my torque converter but I have some questions, ive swaped converters before but I was able to take the inspection cover off to get the bolts out of the flexplate, how do you do it on the 4l60e? And my other question is how much fluid do you add to the converter before you install it into the trans? Thanks
Most converters won't take much fluid at a time. I add a little go do something else then add more. I think some of the little 8" converts I run took a little less than a quart.
Former Vendor
The converter will get totally filled when you start up. The transmission will pump fluid into the converter. So don't worry about getting it totally full. But I do suggest getting about a quart in it so it is not dry on start up. Make sure it is lubricated. You also want to make sure you have the trans pan full before startup, so it has some fluid to pump into the converter.
Chris
Chris
BennyB
08-01-2015 08:48 AM
KyleW707
07-29-2015 08:17 AM
