torsion bar coil over swap
Old 02-09-2011 | 07:03 PM
2004SSS's Avatar
Default torsion bar coil over swap
anyone ever seen anything like this on a stock/lowered suspension setup? it would be nice to get rid of the torsion bars/keys and torsion bar crossmember for some weight loss with the adjustability of coil overs. not to mention for drag/autocross setups. not sure how much room there is but a tubular control arm would be nice to go with it. i know djm has control arms for lowered setups , i could go that route and modify but id prefer hollow instead of solid . the o.d. of the springs would also have to be able to clear the uca and half shaft.
Old 02-09-2011 | 07:17 PM
Bluchevypick's Avatar
I did some research on that a long time ago but decided it would cost me way too much. If i recall, Parish did it to the blue truck before he sold it.
Old 02-13-2011 | 10:04 PM
southern_chevy's Avatar
yes he did but he also ditched the 4wd to I believe. I would not think it would be to bad the new trucks went back to coil springs.
Old 02-14-2011 | 04:55 PM
dlt76028's Avatar
It would be cool to put some nnbs struts up front.
Old 02-14-2011 | 05:12 PM
Dezert1500's Avatar
Wouldn't be to hard. You could probably fit a 2.5" coilover up there. I should have ran coilovers from the beginning but didn't because I wanted to keep the stock coil bucket if I went back to stock. I've been thinking about doing coilovers again lately though. Best thing is to get the OD of a 2.5" coilover spring and start measuring.
They make longer coilover mount ends that would probably need to be run to clear the half shaft. I actually had a pair of King mount ends in my truck I keep forgetiting to take out I could have shown you yesterday.
Old 02-14-2011 | 05:20 PM
2004SSS's Avatar
how much does a set of those run ? not sure what id do on mount location since making a new one may be tough on the stock arm .
Old 02-14-2011 | 05:29 PM
262_NBS's Avatar
Subscribed.....what would be an ideal spring rate and height for a 2.5 coilover? I would be interested in some 2WD front coilovers because i'm tired of replacing spring isolators and dealing with the "chevy lean".
From researching OEM coil/shock setups, it seems the Toyota Tundra has some beefy front units
Old 02-28-2011 | 10:21 PM
dlt76028's Avatar
sill interested if anyone has done this? all I could find were some expensive kits that were way over built for dd.
Old 02-28-2011 | 10:38 PM
2004SSS's Avatar
are you looking like pre runner style? for off road? there are some nice 4x4 kits but your right they are $$$ . enginerring is worth it in some of them though. boxed lca's are sexy and buff .
my goal is to have something that i can control lift and keep it planted . im putting something together now that will accomplish this and will get me lower in the process.
just gotta find a deal on the shocks im targeting , those ****'s are $$$$$$
Old 03-01-2011 | 03:13 AM
BadAssChevy327's Avatar
there was a guy on the silverado ss forum or gm full size forum doing this swap on his 2wd SS i think. i never saw any finished progress but i also havent been on either site for months.
everytime im under my trcuk i sit there thinking of a reliable way to set it up with front coilovers
Quick Reply: torsion bar coil over swap
