tow rating on a 1500hd?
Old 05-15-2009, 04:07 PM
dlt76028's Avatar
so you were only towing around 5300lbs? thats not very much. about 10yrs ago my grandpa crossed over the scales at 16,500lbs in a 82 dodge single cab 1/2 ton with a 318, and drove all the way from idaho down here to texas i dont think he could get away with that these days
Old 05-15-2009, 04:38 PM
Dgrown's Avatar
5300lbs??? my truck weights in at 7500 alone and the trailer is 4500 with 100 gallons of water i dont know how much that weights
Old 05-15-2009, 04:41 PM
dlt76028's Avatar
yea i was just saying how much you were pulling.. 4500+ 100 gallons of water. 1 gallon= 8 pounds.
Old 05-15-2009, 07:52 PM
PT's Slowest Truck
budhayes3's Avatar
You sure about that 7500? If you're going by the sticker in the door, that's the GVW which is the weight of the truck with it's full load capacity. I would think that your truck weighs more like 5700 at most...
Old 05-15-2009, 08:09 PM
dlt76028's Avatar
i think your right
Old 05-15-2009, 10:09 PM
WJ MARK's Avatar
x2 i can't see an HD crew cab weighing 2k more than my ext cab 4x4
Old 05-15-2009, 10:49 PM
GMCtrk's Avatar
Im laughing at the 7500lbs. It's like a dick measuring contest. That truck weighs about 5800lbs from GM.
Old 05-16-2009, 09:58 AM
Mort's Avatar
Mine weighs ~ 6000 lbs.
I used to get ~ 9 to 12 mpg(US) depending on conditions towing 5000 lbs. @ 75 mph. Sometimes I was at 4500rpm in 2nd to maintain 50 mph up some of the longer and steeper grades.
Old 05-16-2009, 10:11 AM
Mort's Avatar
The GVWR of the truck and total load is 8600 lbs.
The max trailer weight for a 4WD is 7900 lbs with 3.73 gears and 9900 lbs with 4.10 gears.
The GCWR of the truck and its total load and the trailer is 14000 lbs with 3.73 gears and 16000 lbs with 4.10 gears.
GM specs.
Old 05-17-2009, 10:24 PM
05HD1500's Avatar
ya, try to look at the registration paper that you put in the glove box, it should have the curb weight. my 05 1500HD has a curb weight of 59XX but with the lift and tires i round up to 6000lbs also...
Quick Reply: tow rating on a 1500hd?
