Tranmission question?
Old 09-22-2007, 08:41 PM
  #21
FLT
FormerVendor
FLT's Avatar
Originally Posted by tweeder
My truck is a 2000 with a 5.3. Now that i'm really confused, how can I tell what I actually have by looking or measuring.
You have the 300mm type M30 4l60e. I know that this is not the best picture but look at the input shaft in this picture.
(Picture above)The oring is is between the stator shaft splines and the input shaft splines. This is a 300mm set up. (Picture below)Here is another photo of just the drum.
Here is a photo of a trans with a 298mm stator and input. Notice that the oring is in front of the splines not between it. This is an early 96 case not that it is important to our discussion but it does use the lt1 style input drum, pump and converter.
Here is a picture of just the drum. It is also a 298 input drum.
Hope this helps you understand what you should have. Vince
Old 09-23-2007, 12:14 AM
  #22
Looking at the pics I have the 60, I think that i'm gonna have to call the guy as I paid alot more for the 65 vs the 60.
Old 09-23-2007, 08:26 AM
  #23
FLT
FormerVendor
FLT's Avatar
I would like to know if in fact it has 5 pinion planets in it. That is what will make it a 65. You might want to ask them that. If they say no then it sounds like they have misrepresented what they have sold you. Just a heads up. Vince
JordanH
12-25-2015 08:32 AM
pewter00
09-13-2015 11:14 AM
TAPyvehc93
09-12-2015 08:19 PM
spooneralmighty
09-11-2015 02:28 PM
chevstang421
09-10-2015 09:16 AM
Quick Reply: Tranmission question?
