tranny cooler
tranny cooler
So when I install my B&M cooler do I use the black zippy tie like things to mount the cooler right onto the Radiator? I was not real sure about that because it came with little mounting plates also. The thing about this is that it didnt come with any instructions and I have never installed one before. Also is the 4ft hose long enough for both line if I mount it in front of the Radiator?
Kinda off topic, but is it really neccessary to go with an aftermarket cooler if your truck has the towing pkg.? When I swapped grills I noticed the factory one in the middle of the grill is pretty good sized. Opinions?
PT's Slowest Truck
Originally Posted by 99Silver5.3
I dont personally like the ties. You can use the brackets that came with the cooler. I mounted thebottom of the cooler to a bar that was in front of the radiator. Then used the brackets for the top. I ended up just pushing the supplied rubber line onto the line I took loose from the radiator. I didnt have to go buy any more hose to install the cooler. I can take some pics if needed.
Vortec350ss
01-12-2016 10:36 PM
lxcoupe
09-25-2015 12:36 PM
