tranny cooler install sticky?
12 Second Club
hey yall i just spent about an hour looking through the search at tranny cooler installs and still dont have a warm and fuzzy on how to install it. Is there a DIY sticky somewhere on the site (or another site) for this. please excuse my retardation but im new to trucks and this site.
thanks
mike
thanks
mike
Where's the Beef?
there are several easy to find threads if you search for cooler in the "GM drivetrain & Suspension" section. They have pictures and all you have to do is look at a couple of the pictures to see how its done.
It's quite simple and the cooler comes with instructions.
You just use a few bolts and brackets to hold it up and then run the 2 lines. Place the brackets however you feel comfortable. As far as the lines you can go through the radiator or bipass the radiator.
If you want to still use the radiator you unhook the bottom line from it and use the adapters that come with the kit to run from the radiator to the cooler and then from the cooler to the trans line.
Make sure nothing leaks and your done.
PT's Slowest Truck
therock
07-25-2015 09:23 AM
