tranny first
tranny first
this is what was adviced from a fellow member on here. i have no mods done at this time, but wanted to have a tranny that could hold up to future mods... it's a 2005 5.3 auto
is there anything missing?
Code Product Quantity Price/Ea. Total
NTP-K51828C Corvette Servo kit for the 700-R4 and 4L60E Transmissions $13.19 $13.19
TRG-4L60E-HD2 TRANSGO GM 1993-UP 4L60E HIGH PERFORMANCE SHIFT KIT STAGE 2 $88.78 $88.78
SNX-77767K SONNAX 700R4 4L60E 4TH GEAR BILLET SERVO $69.50 $69.50
ACU-8680501 700-R4 4L60-E LONG SERVO PIN $18.50 $18.50
NTP-K51782E 4L60E / 4L65E 1-2 ALUMINUM ACCUMULATOR PISTON SMALL PIN $8.50 $8.50
SNX-77701-076 SONNAX 700R4 4L60E SERVO RELEASE CHECK VALVE $12.70 $12.70
SNX-77704S SONNAX 4L60/700R4/4L60E 5 PACK 1-2 ACCUMULATOR SPRING $9.83 $9.83
TRG-46-PLT-96 TRANSGO GM 1996-ON 4L60E SEPARATOR PLATE
it depends how much power you are going to try to push through that tranny. different people will tell you different things, some people had their tranny go at 20k miles on a bone stock truck, mine went over 142K with servos only and you know my mods, most of which were done around 120K.
you asked about servos and shift kit, i sent you the list of stuff i would get if i was only going to do servos and shift kit.....
lol i know its ur list... it's everything u sent me... lol.. i lost ur number cause i wanted to make sure i wasnt missing anything
i'm only lookin for enuff to handle a magna charger...
Why buy the 1-2 accumulator spring kit when the transgo HD-2 kit comes with them? Your also replacing the 1-2 accumulator piston because it is plastic, you should also replace the forward piston, it is plastic also, and will break just as easy as the 1-2. And a large cooler would be a good investment also.
And on the Hd-2 kit, make sure you specify that you have an 05' model and get the latest kit. If not you will get the older style boost valve that will not fit in your trans.
