tranny problem 4l60 to 4l80 swap
but if im running a 5.3 tune how would i get those 2 wires to work off the computer???? i just ask cos before i got it flashed it wouldnt shift. after i flashed it it started to shift but it would only shift at 3000 rpms
High on diesel fumes
yeah that is the same wire diagram i used..you think it could be somthing with that??? but the only thing i had a problem with was it says u... their is no u on the wire diagram so we just did it with v. if that makes sense. pretty much we cut the brown and white wire and connected the white wire that come out of the plug with the brown wire that come from the harness. is that write i dont think we did anything else with the plug. and we ran 2 wire from the computer from the pins it says on their straight to the second iss sensor
I think there is a little bit of confusion happening here.
Baja, leave the 6.0 tune in the computer, but all the engine parameters need to be changed for the 5.3. You did the right thing in putting that 6.0/4l80e tune in the computer, now you just need to make sure the computer knows you have a 5.3 and not a 6.0.
And get that wire changed on the connector....
Need to get a Engine Segment swap for the 5.3/80E combo..
Also, the wiring is really simlple.. The last wire on the connector (brown), you take that and move it to where the White wire is.. no need in cutting or anything.
Add the Front VSS wires to the PCM and get the PCM flashed like its suppose to be with the Segment swap for the 5.3..
Oh ya, mods, can u move this to the GM Drivetrain Section?
EFI live has a tool where you can copy the engine parameters from another tune into yours. It takes literally 5, 10 seconds. I had to do it for mine. For example, I have a cable TB 6.0, so I needed a 6.0 tune for a cable TB, but all they had on the holden crazy repository was 6.0 tunes with ETC with the 4l60e. The only 6.0 tune I could use was with a 4l80e, so I simply used that tune and did a trans segment swap from a 2002 4l60e
HPtuners has a function to view, and copy, the differences between two tunes. I'm not a pro at it, but you should be able to load your tune (6.0) and then open a compare (5.3) tune. Go to the comparison log and copy over the differences.
Since the 6.0/4l80e tune you loaded was from a different vehicle I'm not sure how the licensing will work on this. If your tuner is doing it he shouldn't have a problem though.
