trans/converter install method
Please post pics or ideas on how you go about lowering/raising your transmission using a floor jack.
This is the only one I've found so far and I need more ideas!
thanks
and anyone do this alone on the floor? or do I NEED an extra set of hands?
thanks
here is the one of my choice but there are others on ebay
http://cgi.ebay.com/ebaymotors/_Auto...1%7C240%3A1318
I use a 2x6 wide enough span the edges of the pan for better weight distribution and balance. You can also use a ratchet strap to secure the trans to the jack if you are worried about it slipping as you pry the trans from the engine. I have done a few 60s by myself but it makes it much easier with a helper when you are on your back on the floor. I am actually going to tackel pulling my 80 by myself one night this week.
PT's Slowest Truck
I will be doing mine, 4x4 with transfer case, by myself. In high school I used to do side jobs with my step father, I pulled the trans and he built it. Always used a floor jack and some 2x4's. Now I have a trans jack adapter that I'll be using when the time comes...although I do have 2 friends who are mechanically inclinded, so I'm undecided. Usually when I ask for help, the help just gets in my way lol.
Where's the Beef?
Kept running into stupid problems that required me to drop the trans again like 4 times.
Ive used that jack before, if you have access to a bike lift that makes it easier if it will go up high enough
obviously I prefer the method with a 2x4 since its my pic but its not difficult once its on there
lxcoupe
08-26-2015 07:24 PM
zblee
08-03-2015 03:45 AM
