which trans. to go with?
i currently have a 4.8 in my truck and i plan on swapping to a 6.0, but my transmission is ready to die now, so im going to go ahead and put a built one in it, but im going to have to run the 4.8 on it for awhile, whats your suggestions on a transmission to go with?
FLT. What are your future goals? Either ET or w/ respect to HP/TQ (@ the wheels) ?
Does it see a lot of track use or are u gonna run a sticky tire?
Do u plan on any FI? Either turbo, s/c, or n20?
A built FLT 60/65e could live (Trever1t has 20k+ miles on his FLT) or for no worries, go ***** out on a 4L80e coversion.
well i plan on a 100 wet shot for time being, and maybe a supercharger one day, definately a 6.0L swap and maybe some track use? nothing to extreme though but i want something htat will hold up to a beaten
2nd fastest 5.3 ECSB
FLT hands down. I have been running mine for over 20K miles without issue. Customer service is top notch and quality speaks for itself. I would advise you purchase the highest level you can afford, you may not need it today but if you are like some of us you will be turning up the power little by little!
Lo&slo, what yr is your truck? TM can be tweaked as trever said. If u have a DBW TB, you'll have 3 strangleholds on the TQ Mgmt side of things. Thats if u have DBW, if cable TB, I believe it's only 2. Someone please correct me if I'm wrong on this.
It would really benefit you to get the tune set up properly with the new transmission. You can alter torque management settings and zero the shift times. Also make any necessary adjustments to the torque signal pressure so the shifts are not too harsh or too soft.
