trans installed, now no-start
Old 05-04-2011, 07:39 PM
01350ss's Avatar
Default trans installed, now no-start
i have replaced the 2-4 band in my 03 yukon today. re-installed everything and now the truck will not start. i have all lights and chimes, the indicator lights work as i move the shifter through the range, we've tapped the starter while turning the key - nothing. When the key is put to start position all i get is silence.
any thoughts - this is on a 2003 yukon 5.3 4wd
oh and i also have "service 4wd" and "check brake booster" on in my display
thanks everybody
Old 05-04-2011, 07:46 PM
Swerve7rpm2000's Avatar
Do you have 12 volts goin to your starter when they key is in start position?
Old 05-04-2011, 07:47 PM
05gmcsierra's Avatar
re check ur wiring.. did u disconnect the battery when u dropped the tranny? if u didnt check ur fuses may b when u were taking off the starter u made a short and blew a fuse.. other then that idk man.. check ur p to N safety connector..
Old 05-04-2011, 07:59 PM
Senior Member
Country Boy's Avatar
Check all your wires and your P/N switch.
Old 05-04-2011, 09:10 PM
01350ss's Avatar
alright guys, which is the p/n switch? anybody have a pic?
Old 05-04-2011, 09:11 PM
01350ss's Avatar
oh and country boy, thats a nice pic there! sharp color on the truck and whoever the lady is, very nice too!
Old 05-04-2011, 09:12 PM
11 sec. Truck Mod
TIM Z's Avatar
You didnt pinch the crank position sensor wire on back of engine did ya??
Old 05-04-2011, 09:19 PM
01350ss's Avatar
never mind on that question. its the block on the side of the case.
i had to tap the top connector into this for it to sit. after tryign to start the truck with no luck, i unplugged both connectors to make sure none of the pins were bent. none were, tried to put the connectors back in and they wouldnt go, so i pulled the weather connector out and tried, i got them back in without tapping. think i messed this thing up? anyway i can check this, make sure the adjustment is right? when i put the truck in park, it does unlock the doors and stops the truck from rolling more than a few inches, so i believe its in park.
Old 05-04-2011, 09:21 PM
01350ss's Avatar
timz, i dont believe so. i didnt see any wires hanging off the back of the engine anywhere. plus wouldnt it still crank just not start
Old 05-04-2011, 09:29 PM
Registered User
Ronnie6.0's Avatar
Check the ground on the back of the block by the top trans bolt , also check the curcit fuses under the hood the should be green 25 with A clear lens ! I didnt disconect the power and blew them
Quick Reply: trans installed, now no-start
