trans overheating with 40k cooler?
Old 01-13-2012, 08:45 PM
  #21
nonnieselman's Avatar
I know your running a 3200 stall but i never could get mine with the stock converter to even get close to 190* pulling a heavy trailer thru the pasture in first gear pushig the converter to 2800 but barely moving. And the fans never come on high.
Id say you got a slipping issue.
Log engine rpms and torque converter slip speed mine throws a -2 thru +2 while towing on the clutch slip.
Old 01-13-2012, 09:47 PM
  #22
david0982's Avatar
Ok Ill check that out and see what i find.
Old 01-14-2012, 02:52 PM
  #23
david0982's Avatar
Well checked the converter lockup % and Its at 95% on cruise at 55mph.
Old 01-14-2012, 03:31 PM
  #24
11 Second Hall Moniter
AKlowriderZ71's Avatar
Were you watching TCC slip rpm?
Old 01-14-2012, 04:55 PM
  #25
david0982's Avatar
Yea where should it be at?
Old 01-14-2012, 05:03 PM
  #26
None. Or only a few RPM.
Old 01-14-2012, 05:12 PM
  #27
david0982's Avatar
yea when it was locked it was none or 1 or 2 rpm.
Old 01-14-2012, 05:13 PM
  #28
That's what you want to see.
Old 01-14-2012, 05:20 PM
  #29
david0982's Avatar
Ok good so you think the problem might be with the vacuum modulator giving the trans too much pressure?
Old 01-14-2012, 05:22 PM
  #30
What is pulling the air across the cooler? Electric fans, or mechanical fan?
Quick Reply: trans overheating with 40k cooler?
