Trans Question.
Trans Question.
What would cause this ? when coming to a corner I let off and coast around the corner and somtimes not always when I accelerate again its like its in nuteral for 1 to 2 seconds and then it goes again. Would it be in the tuning or mechanical in the trans itself ?
FormerVendor
Not sure when you serviced it last but are you sure there is a filter in there? I would also make sure that the seal in the pump for the filter is good and tight. From what you are describing it seems as you are loosing the sump. If all that is good then I guess it is possible that you have an internal issue. However why doe it only happen on turns. Weird. Vince
PT's Slowest Truck
