Trans Temp Gauge Installation
I have an Autometer 2 5/8" mechanical gauge I want to install in my '00 ECSB. Can anyone tell me what the best route to the trans from the cab is? The capilary tube length on the gauge looks like it's got to be a fairly straight shot. I'm going to hook it up to a Dearle deep pan on a 4L60E. Gauge mount options can be either in the Autometer bracket under the dash or in the dash.
Thanks.
Thanks.
Resident Retard
2x on returning the gauge.
I have had a gauge in 2 different spots. The first place was in the cooler feed line. This basically gave the temp of the fluid exiting the trans. After a long WOT run this temp was like 190*. But The internal trans gauge said 120*.
Honestly if i add the gauge back i plan on putting it back in the cooler feed line like before.
I can't return the gauge for electric. The Dearle has an integral boss /fitting for the mechanical gauge. Reading temp in the pan shouldn't be a problem and should be representative of the temp. the trans is operating at shouldn't it? The trick is getting through the cab floor to the trans pan.
Thanks!
Sweet location. I have the same color interior. Gauge is the black face. My airbag on/of key switch is located in that spot. Was your's? If so, where did you move it? How did you run the capilary tube? Straight down behind the console and through the cab floor?
Thanks!
Thanks!
It looks better now that its all painted up and cleaned up, that was a quick pic when I was putting it in, I wish the guage was black aswell but it was a spare guage that I had for my car.
FlowmasterMufflers
07-17-2015 03:26 PM
Nimoryan
07-05-2015 03:50 PM
deep, gages, gauge, install, mechanical, moroso, pan, plumb, sensor, silverado, temp, temperture, trans, transmision, transmission
