trans took a dump need help.
ok so the truck starts out in first no problem then it revs real high skips 2nd gear then goes straight to third... so i have lost 2nd gear... also if you punch it in 4th gear it hits the rev limit at 6800.... so i only have about 2300 in the truck bank account right now , and i dont want to get into my reg checking account... what should i do? 2300$ isnt much to work with... my tranny is all stock.... also i had a deal on an 80e slightly used but it was sold before i could get my hands on it...
yeah ive done more since i last updated my sig.. my truck does 463 hp and 401tq at the wheels... i was thinking of taking my truck to aamco ? as i dont have enough money for a flt.. becouse i cant do the work myself...
Hunt&Fisherator
Ill have about 13-1400 in my 80E swap.... Crossmember, tuning, stall converter, trans, shift kit, driveshaft and all.... You should consider tackling it yourself. Someones going to charge out the nose to do an 80E conversion simply because they'd consider it "custom" work...
i hate to keep asking stupid ?s but im still a noob.. so ive decided to go with a built 60e due to lack of funds... so i have a 2300$ budget.. what should i tell the trans shop when i take in my truck tomorrow? think i can get a well built 60e with a converter.. somewhere around 3000 stall? i can push it to 2600$ if its a must... i would like your guys opinion on this.. thanks..
your prob equiped with a 4l65E . . the difference is the pump/ BAnd . . you need red/blue clutches/ 5pinion planetary/ beast sunshell/ shift kit+ both billet servos / hardened imput+ output shaft's / alto wide band / + other good stuft i dont know off my top of my head. Make sure you get a tru-cool 40K tranny cooler , while yout at it * . . ask your local tranny guy, for all the good stuft for ur tranny.
