TransGo .500" Boost Valve
I just got around to putting a Vette servo in my transmission. While doing searches on the web I noticed it is recommended to change the Boost valve in the pump on the 4L60E. My question is, would the TransGo 4L60E-BOOST at .500" be to much, if I am able to dial back the line pressures with my Predator v2.12 U7198. I'm on a tight budget and can't find the .472" valve for similar prices.
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
Transmission is in truck with 67K miles and seems to be in good condition. I filter changed and flushed with RP Max ATF @ 35K miles. Just want to do some PM to prevent any problems. I've had the Predator program in since 01' or about 7k miles, so line pressures have been a little above stock most of it's life.
Personally I'm not a big fan of hand held programmers but that's just me. I don't see an issue with you using the TG kit you linked. I personally have been using the sonnax kits in my builds and I feel it is a better valve. Sonnax now sells a booster kit that includes a pressure regulator spring and the boost valve and sleeve. I don't think that they are that much money but they probably cost more than the TG valve you have listed.
GXPJAY
02-13-2022 08:15 AM
LSX-81-SIERRA
08-31-2015 05:52 PM
lycominghunter
08-15-2015 12:26 PM
zaathur151
07-06-2015 10:57 PM
