TransGO HD2 install - Boost valve
I'm not running a stall, bone stock 4.8. I am building a camed 6.0 to put in with in 2 months. I haven't decided on a stall yet. I was thinking around a 224/224
I did not use the shims. I drilled the smallest bit for each hole. I couldn't rotate the shaft to check for the slack. I'm guessing that's where some of my problem is.
zaathur151
07-06-2015 10:57 PM
3rd, 4l80e, accumulator, bad, boost, boostvalve, cab, hd2, performance, shim, spring, tootall, trans, transgo, valve
