Transgo installed after about 12hours!!
So what tips can I give to you guys when installing all of this?
Servo's
1. The servo's are cake, don't be intimidated. The hardest part is putting back in that damn snap ring on the cover. An experienced guy could do them in under an hour. A non-experienced guy could do it in less then two.
2. Have a drip pan and a few rags handy. Some fluid will come out. Not a lot, just a few tablespoons.
3. Make sure to have a prybar or really big screwdriver. You'll need this leverage to push down on the cover and to reasemble.
Transgo
1. Have plenty of rags. We went through about 25 rags.
2. Take your time and follow the directions to a T. The video doesn't exactly match the directions, but the video will get you about 80% there. Where there are discrepancies, go with the printed manual.
3. Get some more shop towels and rags.
4. Have a large and clean work bench ready for the valvebody and transgo parts.
5. The video nor printed manual list torque specs, they just say to tighten evenly. That to me is around 12-15ft/lbs.
6. The 4th accumalator piston and pin may have a tendancy to fall out. Just put a dab of grease on it to keep it put.
7. Buy an extra screen(s) for the separator plate. There are two (each a different size), believe me it's not hard to break one of these things when your trying to force them in. The cost from Chevy was just around $3, there is an AC Delco version as well that costs a bit more at around $13.
Servo's
Transgo
Thanks fo the heads up. I've been wrenching on my stuff for a while. I'm pretty confident and will dive into most things, but i'm still intimidated by tranys. I thoughe the servo was a cinch, but was scared at firsr. I need a transgo, and converter, but was contenplating taking it somewhere till I read this. Thanks guys for the experiences.
what a rush!
Servo's
Transgo
Servo's
Transgo
what a rush!
Originally Posted by Naked AV
How true that is. If I had known my installer was riding their reputation and doing bad work, I would have gone elsewhere...
Thanks, I didn't think it could have been any harder than the cam install, and I was right. Thanks for being a great example of someone learning by doing.
