Transgo Shift Kit which one is better
Im buying a transgo sk today or tomorrow but which is better the normal kit or the hd2 kit is it really worth it to get the hd2 kit.thanks
The HD2 kit comes with:
.500" boost valve w/ matched pressure springs
4th accumulator spring
revised 2nd accumulator setup (two springs, spring seat, washers, etc...)
Red & white accumulator valve springs (use per instructions)
revised 1-2 shift valve
3-2 downshift spring
AFL valve spring
PWM delete valve & spring
High-rev springs (if trans is apart)
Servo cushion spring & adjustment shims
gaskets
drill bits.
instructions.
Servo is not included in the HD2 kit.
AFL valve spring
gaskets
drill bits.
instructions.
lycominghunter
08-15-2015 12:26 PM
zaathur151
07-06-2015 10:57 PM
