Transmission Fluid Change/Flush?
If it ain't broke , don't fix it.....
Mine hit 200K this am. It has never been serviced. I might have had add a little here and there but nothing to major. I'm working on a new built and stall for "when" it gives up the ghost but going to ride it out untill then.
I agree^^^.. I would also agree that if the trans hasent been serviced in 100k i would not have it flushed but i would drop the pan change the filter and refill..
My transmission was never serviced for 284k. I dropped the pan changed the filter and added 5qt's of dex 6. Transmission still shifting fine, with no signs of slipping, will do another drain, refill, and filter once i do an oil change.
if you find a reputable shop with the BG fluid exchanger you will not have a problem. it uses the transmissions pump to exchange the old fluid with the new fluid. my gtp has had its built trans "flushed" with this machine 3 times, my sierra will be getting it in a couple of weeks too. hope this helps
drummer0415
11
10-24-2015 08:16 PM
ice17
09-22-2015 05:18 PM
bluestang50
09-21-2015 08:36 AM
